Activity › Forums › Apple Final Cut Pro Legacy › Quicktime 7 and FCP HD??
Posted by Colin Williams on May 7, 2005 at 4:14 pmWas curious to know if anyone is having any issues with the new Quicktime and it’s compatibility with FCP. I may have discovered a bug with the new h.264 codec. Not sure. Maybe it’s a corrupted source file. I don’t know.
Shed light please.
Cheers,
Colin
Chris Poisson replied 21 years, 4 months ago 4 Members · 6 Replies -
Chris Poisson
May 7, 2005 at 4:50 pmHey Colin,
Doing a test right now, from an 8bit timeline to h264 QuickTime conversion of a :30 second spot. Seems to be going alright, although pretty slow. Looks like it’s gonna take about 15 minutes on a G4 1.42 dual with 2 gigs of RAM, Tiger and QT 7 Pro.
A few minutes ago I tried doing a self-contained Quicktime and FCP shut down.
I’ll let you know what happens…
Chris Poisson
May 7, 2005 at 7:10 pmHmmm,
The resulting movie from my test was black. It took about 15 minutes. Something’s not right.
Chris Poisson
May 7, 2005 at 7:40 pmTried another one and turned keyframing from the default 24 to automatic, and it worked. Only took about 6 minutes.
Encheval
May 8, 2005 at 9:21 amYeah, i have some issues myseself with H264, 3mn clip stopped exporting (I left the office and back from lunch…. still the same !) but 30sec spots are ok.
Also i had FCP HD quitting without any reason a few times and some skipped frames in references files.
Nico
Colin Williams
May 9, 2005 at 3:53 pmThanks for your test. I went as far as trashing some of my source files that were in the sequence. My sequence was only a minute long. I’m wondering if something is corrupted in that particular project file that was initiated by the QT 7 install? Any other findings or possibilities?
Colin
