Activity Forums Media 100 QuickTime 6.5.1 or Is 7.x OK on M100 8.2.3?
  • QuickTime 6.5.1 or Is 7.x OK on M100 8.2.3?
    Posted by Matt Cahill on July 3, 2006 at 11:26 am
    I see from various posts that some people have upgraded to QT 7.x, but as far as I can tell, it’s not an official endorsement. I wonder if Floh, or someone would clarify, or point me to the most stable solution on this score.
    Last week, I tried to export a 3min peice using MPEG 4, then a plain vanila QT (w/7.0.2) loaded on my machine, and after about 45 seconds in the play back video froze but the audio stayed. Export was configured w/ 640×480, 30fps, in other words, as simple default QT file. I figured it has something to do with my impetously loading QT 7 (last July), and so I tried to remove version 7.x and reload QT6.5.1. However, I discovered to my chagrin, my system, once upgraded to 7.x, will not allow me to go back to 6.x. (Apparently, when upgrading to 7.x, I didn’t read the caveat explaining this, so a friend of mine informs me).
    Am I going to be better off going to scratch and reloading everything?
    I do apologize for cluttering up the posts here with such neophyte ‘shoot first ask questions later’ kind of mistakes. But, I do appreciate the quality and professionalism of the advice I read here even if my actions belie me.
    So, thanks in advance. . .
    dual 800/10.3.9/M100 v8.2.3
    Bruce Mcpherson replied 20 years, 2 months ago 2 Members · 3 Replies
  • Matt Cahill
    July 3, 2006 at 11:37 am
    [Matt Cahill] “Export was configured w/ 640×480, 30fps, in other words, as simple default QT file.”
    Er, the footage was imported 720×480, and exported as above, could this have caused the video to stop rendering after 45 seconds?
  • Matt Cahill
    July 3, 2006 at 11:47 am
    [Matt Cahill] “Am I going to be better off going to scratch and reloading everything?”
    Er, as opposed to using Software Updater, but that would load the now current QT 7.2.x., a system update clearly intended for Tiger, and hence unadvisable for me.
  • Bruce Mcpherson
    July 3, 2006 at 12:56 pm
    Hi Matt
    I know that Qt 7.01 on 10.3.9 and M100 8.2.3 worked ok for me. Also I have found in the past that you cannot easily go backwards with some installs, (particulary O/S installs and now it seems QT flavours as well!)
    So maybe the solution is to update the O/S to 10.4.6 as M100 says this is ok.(then all your planets are in alignment 🙂 ……)
    Anyone else?
    cheers
    Bruce Mc
