Activity › Forums › Adobe After Effects › Quickly scroll through a list in AE?
  • Quickly scroll through a list in AE?
    Posted by Filip Stillerska on April 5, 2018 at 5:40 pm
    Is there any way to quickly scroll through a list in AE (such as the one shown in the example below) without having to first click on the list to open it and then select an option?
    Steve Bentley replied 8 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • Steve Bentley
    April 5, 2018 at 6:20 pm
    example below?
  • Filip Stillerska
    April 5, 2018 at 9:23 pm
  • Steve Bentley
    April 5, 2018 at 10:58 pm
    So like the blend layers with shift/=. Not to my knowledge there isn’t (and yes I’ve wanted something to test out different looks without having to look where I was mousing)
    You might be able to tie a slider (set to integers) to the effect’s parameter with expressions. Dan Ebberts on the AE expressions forum might know a way to pull that off.
  • Filip Stillerska
    April 6, 2018 at 11:32 am
    Still works! However, I’m trying to achieve this for all types of lists.
  • Roland R. kahlenberg
    April 6, 2018 at 5:00 pm
    Up/Down arrow keys are the fastest way to go through a list in AE.
    PathSlicer – Advanced AE Shape Layer Effect
    https://www.broadcastgems.com/pathSlicer
    – create highly customizable custom animated typefaces
    – create amazing transitions
    – create cool lower 3rds and panels
    – create burst effects
    Do it all on a single Shape layer with minimal keyframes.
    TypeGEMs – The Most Complete Type Tool Effect for AE
    https://www.broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    BorisFX mocha Certified Instructor
  • Steve Bentley
    April 6, 2018 at 6:03 pm
    hey its as easy as this – put this on the menu parameter in question of the effect (this was done on the fractal noise fractal type parameter) and you can slide through all the settings. Its got a rounding on it so only integers go to the effect.
    Math.floor(thisComp.layer(“Null 1”).effect(“Slider Control”)(“Slider”))
  • Steve Bentley
    April 6, 2018 at 6:05 pm
    You can also select the slider value and nudge it one setting at a time with the up or down arrow keys.
    Depending on your layer stack you may need to put the slider on another layer. (as I did).
    You can just keep staring at the screen and rip through all the options.
