Activity › Forums › Apple Final Cut Pro › Quickly Find SloMo Clips
Posted by Jeff Krieger on February 15, 2023 at 8:17 pmHi, is there a way thru a Library Smart Collection – or any other way – to quickly filter/find all the slo-mo clips in a library? Thx.
Ben Balserreplied 3 years, 5 months ago 3 Members · 5 Replies
Ben Balser
February 15, 2023 at 9:12 pmSmart collections rely on metadata. What metadata is connected to your slo-mo clips? Are these filmed at faster frame rates in the camera? Cause then you could specify Frame Rate for the smart collection. Are you referring to clips slowed down in the Timeline? No, that’s specific to the Timeline, no metadata gets fed back to the Browser. Or you could create a Keyword collection and import all slow motion clips directly into it. But there has to be some data/metadata that FCPX will recognize to create a Smart collection with. What would that be for your clips?
Jeff Krieger
February 16, 2023 at 4:47 pmThx much. Yeah, I’ve tried that. I think the issue is that even my slo-mo clips are showing a frame rate of 23.98. Shot on Sony FX6. Not sure why FCPX is reading them as that.
John Fishback
February 16, 2023 at 5:01 pmThis would be a bit of a pain, but you could rename each slo-mo clip with SM01…SMxx. Then you’d see them all in the timeline index.
Jeff Krieger
February 16, 2023 at 5:03 pmThx very much. Yeah, trying to get Final Cut to do the work for me of recognizing which clips are slomo.
Ben Balser
February 16, 2023 at 11:57 pmKeyword collections would be faster than renaming the clips. When importing, have that collection highlighted, and they’ll import directly into that collection. If you right-click the Browser headings (in List mode) and select to show Video Frame Rate, you can then sort them by FPS. Select all of those clips at once, drag them into the collection. Too bad Smart collections don’t have a Video Frame Rate option.
Where are you seeing that FPS? In the Browser column?
