Activity Forums Adobe Illustrator Quickly create artboards with various sizes from list of measurements
  • Quickly create artboards with various sizes from list of measurements
    Posted by Nicole McLean on November 10, 2023 at 5:23 pm
    I have several projects that need 15-20 artboards in one file with multiple unique sizes. Right now, I create each artboard individually working of a long list of typed out measurements . Is there a script or something that would allow me to copy and paste in the measurements for each artboard and then have illustrator create them all at once? It would save me hours of work a week if I can find a way to do this.
    Jan Harm van der Walt replied 7 months, 2 weeks ago 3 Members · 3 Replies
  • Oscar Polanco
    November 15, 2023 at 6:13 pm
    There is no way to create multiple artboards in illustrator with different sizes from the beginning. An option would be to create a different box shape with the size that you need. That way if you need 15 different artboards with different sizes you can create 15 boxes and then go to “object” menu / Artboards / fit to selected art.
    This way you’ll get a different artboard with the exact size of all the boxes that you created.
    If the same size is repeated over the documents this would be a good way to save time typing the measurements multiple times.
  • Jan Harm van der Walt
    June 5, 2025 at 7:48 pm
    Hi Nicole!
    You could also try the Multiple Artboard Generator for Adobe Illustrator script I created:
    https://iamharm.gumroad.com/l/MultipleArtboardsFromCSV
    This script creates multiple artboards for you all at once in Adobe Illustrator from a spreadsheet (csv file). You specify the names for the artboards and their dimensions in the csv file and the script will do the rest. When you run the script there is a dialogue box that will allow you to specify the units (pt, px, mm, in) as well as the spacing between the artboards.
    I also made a video showing how it works:
    https://www.youtube.com/watch?v=ENenxnNjbf4
    December 2, 2025 at 6:59 am
    The Multiple Artboard Generator for Adobe Illustrator extension has moved to aescripts at the link below:
    https://aescripts.com/multiple-artboard-generator-for-illustrator/
