Activity Forums Adobe Premiere Pro Quickly changing still images duration to synch with titles
  • Quickly changing still images duration to synch with titles
    Posted by Rok Picasso on November 17, 2012 at 1:14 pm
    Hi. What is the fastest way you can think of to change the duration of a series of still images, so they match the duration of several Titles in another video track?
    Currently, it feels too fiddly, repetitive, and time-consuming to manually adjust the duration of dozens of images so they match the duration of the Titles in the video track above them. Worst thing is: ripple delete sometimes doesn’t work (faded) for some reason, so I also have to drag chunks of 2+ still images on the track, to snap them to the ones before them, and so on. Nightmarish stuff, to be frank, for someone who is essentially trying to “tell a story”, rather than design an intricate layout or something!
    Many thanks for everyone taking the time to share tips and help.
    Gabriel Sanchez replied 13 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Angelo Lorenzo
    November 17, 2012 at 7:53 pm
    Highlight multiple clips adjacent to each other, right click, select speed/duration, adjust to your heart’s content and select ripple.
    Beyond that, if each still needs to be a unique duration then you’ll have to settle for manual adjustment.
    Alternately, if you have After Effects you can do some scripting because you can tell the script okay, make layer 24’s duration equal to layer 3.
    It could also just be a workflow issue. Maybe you can elaborate as to why these titles are locked in time to force you to adjust the more granular slideshow cuts.
    Angelo Lorenzo
    Love my answer? Do me a huge favor and check out my Kickstarter project The Librarian, starring Jennie Garth of Beverly Hills 90210.
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Rok Picasso
    November 17, 2012 at 8:02 pm
    Thank you, Angelo.
    Yes, each Title has a different duration, so selecting all is not an option unfortunately.
    The After Effects tip is potentially powerful and relevant. I’m not familiar with its scripting, but I do some CSS, know basic JavaScript, and very familiar with XHTML; so where can I start to learn After Effects’s scripting?
    The Titles must have those different duration values because they are synched with the voiceover audio. Does that clarify or invite any solutions?
  • Angelo Lorenzo
    November 17, 2012 at 9:02 pm
    After Effects uses ActionScript which is a variation on Javascript.
    You’ll probably notice that Premiere and After Effects installed “Adobe ExtendScript Toolkit”. This is the development environment for ActionScript. Premiere is included as a program within it, but is nearly unscriptable (I think it’s there in case you want to grab properties for AE or another program)
    https://www.motionscript.com/ lists some good resources to start.
    https://library.creativecow.net/toula_jesse/AE-Scripting-1/1 is worth looking at too.
    Angelo Lorenzo
  • Rok Picasso
    November 17, 2012 at 9:12 pm
    Many thanks for these resources and the explanation, Angelo!
  • Gabriel Sanchez
    November 18, 2012 at 12:56 am
    In PPro, you can place sequence markers where titles start and finish, then select all the images in the proyect pannel and click automate to sequence button, select “place in markers” option in the automate to sequence window. To avoid pictures being shorter than any space between two markers, and having to refit manually in the timeline, select a longer duration for still images BEFORE importing pictures in the “Still images duration” option in the General tab of the Preferences.
    Regards
  • Rok Picasso
    November 18, 2012 at 1:12 am
    Sheer genius, Gabriel!!
    I’m stunned, man. I had about 1% hope that there [is] a solution for this problem, and thought that I’d be stuck with manual tweaking until Adobe just improved the program, but this really does work! It’s awesome. I just used the up arrow and M, over and over again very quickly to place those markers, and the rest worked like a charm, just you described.
    Thank you so much, mate! You’ve probably saved a lot of time for which I hope you will be rewarded (karma!). =)
  • Gabriel Sanchez
    November 18, 2012 at 8:26 pm
    You´re welcome, I´m glad to have helped.
    Regards
