Activity › Forums › Apple Final Cut Pro › Quickest way to fill a gap between two clips with video from the audio below them ?
  • Quickest way to fill a gap between two clips with video from the audio below them ?
    Posted by Luke Will on September 25, 2018 at 8:24 pm
    What is the fastest and most efficient way to achieve the following with shortcuts:
    On the timeline you have an audio clip with another separate video clip on top, and you cut a section out of the top cutaway so there’s a gap in the middle, and you want to fill this gap with the video associated with the audio clip below it?
    Luke Will replied 7 years, 12 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    September 26, 2018 at 11:46 am
    Match frame from the in point of the audio (shift-f).
    Select the gap in the timeline if it’s a gap clip, or mark the range if there’s no gap clip.
    If there’s a gap clip, hit shift-2 to switch to video only mode and hit option-r to replace from start. This should replace the gap clip with the match framed video from the audio in your timeline.
    If there’s no gap clip and you marked a range, hit “q” to add the video as a connected clip from the matched framed audio.
    Afterwords, hit shift-1 to make sure you switch back to audio and video editing mode.
    If this makes no sense to you, send a screengrab of the area of your timeline.
  • Luke Will
    September 26, 2018 at 12:49 pm
    Wow thanks so much for the excellent work flow method. It makes complete sense. You are a gentleman !
