Activity Forums Adobe After Effects Quickest way to animate a map with multiple dots
  • Quickest way to animate a map with multiple dots
    Posted by Jesse Gibson on April 3, 2013 at 1:57 pm
    I’ve got a Illustrator file which contains the map attached below and about 15 coloured dots on different layers which I’ve currently animated on manually to represent cities on the map.
    I’m keen to create an effect of the map gradually (albeit quickly) filling up with the coloured dots (within the bounds of the countries) before transitioning out. Obviously to duplicate and position the dots in Illustrator and then add the layers in AE by hand would be very fiddly and time consuming so I’m wondering if anyone can recommend a better workflow solution. Is it possible to use particle generator effect(s) to create this?
    Jesse
    5762_mapwithdots.jpg.zip
    Jesse Gibson replied 13 years, 5 months ago 3 Members · 3 Replies
  • Kevin Reiner
    April 3, 2013 at 3:26 pm
    You could probably get something done with “card wipe” or “card dance” rather quickly (if you are familiar with using those plugs). The difficulty would be in getting the alignment done, but after that, there are many options that are easy to get to.
    Mac Pro 2 x 3 GHz 6-Core Intel Xeon
    32GB Memory
    Dual-channel 4Gb Fibre Channel PCI Express card
    Dell Display (23″ flat panel)
    ATI Radeon HD 5770
    AJA Kona LSi SD/HD capture card
    Rourke 16 TB
    Flanders 2460
    SOFTWARE
    Mac OS X 10.6.5
    FCP 7
    After Effects CS5
    Boris Continuum
    Sapphire Plug Ins
    All Trapcode Plugs
    Zaxwerks Invig
  • Walter Soyka
    April 3, 2013 at 4:22 pm
    [Jesse Gibson] “Obviously to duplicate and position the dots in Illustrator and then add the layers in AE by hand would be very fiddly and time consuming so I’m wondering if anyone can recommend a better workflow solution. Is it possible to use particle generator effect(s) to create this?”
    You could build the multi-color, dotted, regular-grid map very quickly with Trapcode Form.
    You can add them over the uncolored map grid via the effects Kevin mentioned or by building a luma matte for their reveal.
    Walter Soyka
  • Jesse Gibson
    April 5, 2013 at 1:01 pm
    Thanks for the tips guys.
    Wasn’t aware of Trapcode but it’s a great suite so getting busy now working it out.
    Cheers
    Jesse
