Activity Forums Adobe After Effects Expressions quick wiggle issue
  • quick wiggle issue
    Posted by Tom Gomez on August 8, 2012 at 9:21 am
    Greetings Folks,
    I’ve got a simple “follow the leader” expression linked to sliders on a control layer.
    By the end of the expression it figures out what its position needs to be, which is great. But in addition to following the layer above it, I also want it to wiggle. I have no idea where to go from there.
    THANKS MUCH!!!!
    -Tom
    a=thisComp.layer("SQUARES - right hand").effect("wiggle a")("Slider");
    b=thisComp.layer("SQUARES - right hand").effect("wiggle b")("Slider");
    w=wiggle(a,b);
    delay = thisComp.layer("SQUARES - right hand").effect("follow delay")("Slider");
    d = delay*thisComp.frameDuration;
    thisComp.layer(index - 1).position.valueAtTime(time - d)
    YOU can help save TimeSpace. Join the Chronos Protectorate!
    https://www.95ers.com
    https://www.SpaceAceMedia.com
    Tom Gomez replied 14 years ago 2 Members · 2 Replies
  • Dan Ebberts
    August 8, 2012 at 1:22 pm
    I haven’t tested this, but try changing the third line to this:
    w=wiggle(a,b)-value;
    and the last line to this:
    thisComp.layer(index – 1).position.valueAtTime(time – d) + w
    Dan
  • Tom Gomez
    August 8, 2012 at 8:36 pm
    PErfect!!!! thanks so much.
