Activity Forums Maxon Cinema 4D quick way to make object’s axis center of that object?
  • quick way to make object’s axis center of that object?
    Posted by Eugene Hooper on June 14, 2009 at 4:38 am
    Hey guys, I’m hoping that this is a simple fix. I’m just wandering as to how I can automatically set the axis of an object at the center of that object. After some parenting as using deformers and whatnot the axis becomes misaligned to where the actual object. If I click on the child it’s fine, but it’s parented to things such as an extrude nurbs object. How can I set the extrude nurbs center axis point to the same one as the child object it is parenting?
    Thanks in advance, Eugene
    Macbook 2.4Ghz Intel Core 2 Duo, 2GM RAM
    Brian Jones replied 17 years, 2 months ago 3 Members · 2 Replies
  • Randy Johnson
    June 14, 2009 at 6:47 am
    While the axis tool is active use the transfer tool.
    /randy
  • Brian Jones
    June 14, 2009 at 1:37 pm
    Structure/Axis Center/Set Parent To sounds like what you want
