Activity Forums Adobe Premiere Pro Quick way to find out RED original recording framerate?
  • Quick way to find out RED original recording framerate?
    Posted by Simon Reichel on August 27, 2015 at 10:02 am
    Hi guys,
    I’m having trouble finding out the frame rate that RED footage was originally recorded in. Up until now I had a shortcut to open RED Player and there in the Metadata it was clearly displayed. Wasn’t comfortable but kinda quickish and worked. Now they updated the player and I can’t find that info anymore. It’s frustrating. Is there a new way in CC15 to quickly find that info?
    Thanks!!
    Jay Thomas replied 9 years, 6 months ago 5 Members · 11 Replies
  • 11 Replies
  • David Roth weiss
    August 27, 2015 at 5:31 pm
    For any file type, simply highlight the file in the Premiere Browser, click on File>Get Properties For>File.
    David Roth Weiss
    Director/Editor/Colorist & Workflow Consultant
    David Weiss Productions
    Los Angeles
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Simon Reichel
    August 27, 2015 at 8:15 pm
    ??? That opens a Finder window.
  • David Roth weiss
    August 27, 2015 at 8:36 pm
    [Simon Reichel] “??? That opens a Finder window.”
    No it doesn’t – you didn’t follow my directions silly.
    I said highlight the clip in the Premiere Browser – you highlighted the clip in the timeline – they work slightly differently.
    If you highlight the file in the Premiere timeline, click on File>Get Properties For>Selection.
    You owe me two minutes of life now Simon for not following directions and causing me to write an unnecessary post.
    David Roth Weiss
    Los Angeles
  • Simon Reichel
    September 9, 2015 at 9:21 pm
    I’ll gladly renumerate you if you explain to me how that properties window helps me in my cause. I’m not finding the original recording framerate in there unfortunately.
  • Duke Sweden
    September 10, 2015 at 2:53 am
    Correct me if I’m wrong (which I probably am since I’m an amateur doofus) but isn’t that info available in the “info” tab? Highlight the clip in the timeline (yes, the timeline) and the info for that clip shows up in the “info” tab. At least it does for h264 .MOV files
  • Bella Gavelin
    November 2, 2016 at 1:04 pm
    Is there a solution to this yet? Seems weird that it is so hard.
    bella
  • Duke Sweden
    November 2, 2016 at 1:06 pm
    I’m pretty sure a couple of solutions have already been provided. Did they not work for you?
  • Bella Gavelin
    November 2, 2016 at 2:08 pm
    With a little detective work… But still no way to see it in the metadata display for instance?
    bella
  • Jay Thomas
    March 3, 2017 at 11:44 pm
    Searching for this myself, how to see the original camera frame rate for an R3D clip in Premiere Pro metadata. Has anyone found the solution yet?
    To clarify, the above suggestions to reveal the clip’s INFO bring up standard clip info but not robust metadata, and not original camera frame rate.
    Any help would be amazing, thanks.
  • David Roth weiss
    March 4, 2017 at 6:39 am
    Open a clip using RedCineX
    David Roth Weiss
    Los Angeles
