Activity Forums Avid Media Composer Quick Toggle Keyboard Layout?
  • Quick Toggle Keyboard Layout?
    Posted by Mike Fournier on August 14, 2025 at 11:19 pm
    Hi there,
    This has been a bit tough to search for, and none of my colleagues knew if it is possible.
    I keep a couple of keyboard layouts saved that are better for specific workflows.
    Is there a way to map a layout to a shortcut key? Rather than having to go to Settings and select it manually?
    Mads Nybo jørgensen replied 9 months, 3 weeks ago 2 Members · 2 Replies
  • Mike Fournier
    November 25, 2025 at 6:36 pm
    FOUND IT, what a joyous day. I’ll post the solution here in hopes that future generations can find this faster.
    You can assign any named setting to a workspace layout, so if you duplicate your preferred/current workspace and type the name of your keyboard layouts in its properties window, you can then assign each workspace to a keyboard shortcut using the command palette (ctrl/cmd+3) and you’re all set.
    November 25, 2025 at 8:54 pm
    Thank you, Mike!
