Activity Forums Apple Final Cut Pro Quick Tipp: Create precise audio crossfades
  • Quick Tipp: Create precise audio crossfades
    Posted by Stefan Buhrmester on June 25, 2011 at 5:52 pm
    Hey guys, here is another one.
    This method allows you create a precise audio crossfade. For example, you can bleed the audio of a clip into the audio of a previos clip, or vice versa.
    1. Select the clip which’s audio you want to bleed
    2. ctrl+s to expand the clip’s view
    3. up arrow to move the playhead to the beginning of the clip
    4. shift+right bracket to select the left audio edge
    5. Do one of the following:
    5a. hit comma or shift+comma several times to nudge the audio inpoint to the left
    5b. ctrl+p and enter an exact amount, eg “-100” to move exactly one second ahead, shift+x to move selected edit point to playhead
    You now have precisely bleeded the audio tracks into each other. Now create a fade.
    6. Drag the fade-out handle from the previous clip to the playhead.
    I wasn’t able to find a way to do this using the keyboard. I’d appreciate any hints on this, if there are any.
    Have fun 🙂
    Stefan Buhrmester replied 15 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
