Activity Forums VEGAS Pro Quick Time Movie Render
  • Quick Time Movie Render
    Posted by Mark Prebonich on November 4, 2010 at 1:06 am
    I took some short video clips using a Kodak 5MP camera (not camcorder) quite some time ago. The camera was placed in movie mode and generated quicktime movie format .MOV files. These files play in Windows Media Player. I tried rendering them to the quicktime format via Vegas. The clips would not then play with WMP and the final file size was quite a bit different. A 1:00 original clip is 12.7 MB and is 640×480 size. In Vegas the file shows as MPEG-4 video. What is the proper render settings. Thanks.
    -Mark
    John Rofrano replied 15 years, 10 months ago 2 Members · 2 Replies
  • Mark Prebonich
    November 4, 2010 at 1:11 am
    A little more info from one of the original clips. Hope this helps. I copied this from the media properties window.
    Streams
    Video: 00:01:25.811, 11.607 fps, 640x480x24, MPEG-4 Video
    Audio: 00:01:25.811, 16,000 Hz, 16 Bit, Mono, µLaw 2:1
  • John Rofrano
    November 5, 2010 at 2:20 am
    Did you use MPEG4 as the format when you rendered with Quicktime? You would need to create your won template for this.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
