quick tags shortcuts not working
Posted by Aaron Dennis on June 19, 2019 at 10:03 pmI have set up quick tags but when trying to add tags using [ctrl + the number of the tag ] nothing happens. it is necessary to type in all tags by hand instead. Any idea why?
Francois Pénzes replied 7 years, 3 months ago 2 Members · 3 Replies -
Francois Pénzes
June 20, 2019 at 1:30 amHi Aaron
I’m sure you already know about this but just in case you accidentally missed something. (you can always go to 5:30 for the more pertinent bit)
https://www.youtube.com/watch?v=20Uc_dMXWzA
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
Vegas Pro 16, User since Vegas 3.0\’\’When the cutting stops, the editing begins…\’\’
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Aaron Dennis
June 21, 2019 at 12:25 amI have followed this and several other instructions that all say the same. If you hit the [ctrl] + the number of the shortcut it inserts the quick tag. When I do this nothing happens.
Francois Pénzes
June 22, 2019 at 7:35 pmHi Aaron
I can’t reproduce your problem on any of the 3 versions of V Pro that I have. At this point, you may have to consider to un-installing (including clean up of the registry) and re-installing.
P.S.: If you do re-install, make sure that nothing else is running. (anti-virus, skype, etc…)
Cheers !
