Activity Forums Avid Media Composer Quick short-cut question
  • Quick short-cut question
    Posted by Paul Allen on March 2, 2009 at 11:25 pm
    Hi All,
    Is there a short-cut key so that when you select a track it automatically de-selects all other tracks at the same time? I keep inserting media and forgetting a track is highlighted so that I find holes in the edit later on. Does such a short-cut exist as haven’t found one in my searches so far?
    Paul
    Avid Media Composer. PC with Intel DP35DP s775 iP35 ATX motherboard. Core 2 Extreme QX6800 2.93GHz. 256MB Nvidia Quadro/FX1500 PCIe 1Gb DDR2
    Ra-ey Saleh replied 17 years, 6 months ago 2 Members · 3 Replies
  • Ra-ey Saleh
    March 3, 2009 at 1:50 am
    Just like CONTROL/APPLE + ‘A’ selects all tracks,
    CONTROL/APPLE + SHIFT + ‘A’ deselects all tracks.
    Do this first, then select the track you want to activate.
  • Paul Allen
    March 3, 2009 at 8:45 am
    Thanks a lot,
    paul
  • Ra-ey Saleh
    March 16, 2009 at 3:53 am
    ps.
    Also, it’s just occurred to me and i don’t know if it’s of any use, but you could also map the ‘Cycle Picture/Sound’ button (in the edit Tab of the Command Palette).
    This ‘cycles’ through All Video/All Audio/All Tracks/No Tracks.
    pps.
    If you want to ‘reverse’ your track selection (i.e. deselect selected tracks and vice versa), just drag from just above the Track icons down to the bottom of the TC Track.
