Activity Forums Adobe After Effects Quick Question
  • Quick Question
    Posted by Henry on November 1, 2005 at 9:54 am
    I have 42 jpegs. I want them to be aligned perfectly but be about 1500 pixels apart on the z axis. Is there anyway to automate this, instead of going. o, 1500, 3000, 4500, 6000, etc….
    Is there a shortcut?
    Thanks in advance!
    Michael Duff replied 20 years, 10 months ago 3 Members · 3 Replies
  • Mylenium
    November 1, 2005 at 10:28 am
    Assuming they are all in one comp and no other layers get in the way, use an expression:
    X=position[0];
    Y=position[1];
    Z=1500*(index-1); //index starts with one so your layers will never be at zero without subtracting the value
    [X,Y,Z]
    Mylenium
    [Pour Myl
  • Henry
    November 1, 2005 at 10:44 am
    Thanks – I have never used this sort of scripting before on expressions – I applied it to one layer – and got an error: Expression result must be of dimension 3, not 1. Error occurred at line 0.
    They are all in one comp with no other layers. I assume you can apply an expression to multiple layers at once? Otherwise, I may aswell do it the other way.
    Let me know!
    Thank you very much
  • Michael Duff
    November 2, 2005 at 5:40 am
    I am not very good at expressions 🙁 ….. but could you show how to do this using a slider to vary the distance in between……cheers
    Michael Duff –
    Southern Cross Ten, Australia
