Activity Forums VEGAS Pro Quick question (multi imaging)
  • Quick question (multi imaging)
    Posted by Tinfish on October 9, 2005 at 8:22 am
    Just a quickie.
    A friend of mine recently made a video using Adobe which
    started with someone dancing, and later that same
    person was multi-imaged so it appeared that three people
    were dancing side by side (cheek to cheek if you like;).
    Is there a simple way to achieve this effect in Vegas?
    Tin
    (UK)
    Tinfish replied 20 years, 11 months ago 2 Members · 2 Replies
  • Peter Wright
    October 9, 2005 at 8:38 am
    Several ways are possible
    One is to use Cookie Cutter (Rectangle) to select a vertical “slice” of the frame, then use Track Motion to move this sideways. Duplicate the Track and move this one so it’s alongside the other – repeat as many times as you can fit, if you like.
    To achieve “cheek to cheek” select one of the events and use Pan Crop / right click to Flip Horizontally and become a mirroe image.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Tinfish
    October 9, 2005 at 10:31 am
    Peter,
    Many thanks for the prompt response.
    I’ll try your suggestion now.
    Oh. One other thing. I was thinking of buying
    Auroa Sky (3d cloud/water generator), but noticed its
    for Adobe After Effects only. Is there an equivalent
    utility for Vegas does anyone know?
    Cheers
    Tin
