Activity › Forums › DVD Authoring › Quick Question About Using SC Files
  • Quick Question About Using SC Files
    Posted by Michael Brodner on August 30, 2008 at 5:40 pm
    I’ve exported HDV footage from Final Cut as quicktime files (not self contained), and brought that into iDVD for burning. I noticed while previewing some of the clips from iDVD, that the deinterlacing is really bad with the heavy motion…will burning the DVD fix this or do I need to go back and export my files with deinterlacing check marked?
    Bones
    Lucas Fazzary replied 18 years, 1 month ago 2 Members · 1 Reply
  • Lucas Fazzary
    September 2, 2008 at 7:36 pm
    You will notice the interlacing on a computer. If you burn and playback the DVD on a software player, it should de-interlace when playing back. Playing back on a set top DVD player the picture should look correct as well (so long as bottom field first is used). You can export with De-interlace checked from FCP as well. You will have to see which looks better to you.
    -Luke
