Activity Forums Apple Final Cut Pro Legacy Quick question about import settings
  • Quick question about import settings
    Posted by Joe Severino on July 5, 2010 at 10:02 pm
    I shot an event with 2 different mini DV cameras (a panasonic and a canon) I imported the footage to FCP 7 via FireWire using the DV/DVCPRO codec. I know I need to go into color to color correct the footage. Would I see any benefit in my renders in color if I reimport the footage using either a ProRes codec or an uncompressed codec (8-bit or 10-bit) via the FireWire port or importing analog from my Blackmagic Intensity Pro card using a similar codec? or should I just do what I can with the codec I already imported the footage at, and hope that I don’t get too much noise with the render in Color
    Mac Pro 3.2 GHz Dual Quad Core
    14GB RAM
    NVIDIA 8800 GT
    OS X 10.6.3 (Clean Instal)
    Final Cut Studio 3 (Clean Instal)
    Logic Studio (Clean Instal)
    Michael Gissing replied 16 years, 2 months ago 3 Members · 3 Replies
  • Kevin Monahan
    July 5, 2010 at 11:22 pm
    Switch Sequence Settings to ProRes if you are not going back to DV Tape, leave it at DV if you plan to record back to tape. I like ProRes LT for this.
    Kevin Monahan
    60 Blu-ray Templates for Final Cut Studio 2009
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
    Follow Me on Twitter!
  • Joe Severino
    July 5, 2010 at 11:32 pm
    I wont add any artifacting from the render by changing my sequence render setting as opposed to a fresh import or sending the files through compressor to change them?
    14GB RAM
    NVIDIA 8800 GT
  • Michael Gissing
    July 6, 2010 at 1:15 am
    You could do a test comparing DV into Color and let it render to ProRes versus Compressor conversion before grade, but my gut feeling is that Color does a great job of rendering the DV footage out as either ProRes or uncompressed. It is quicker to do it in Color if you are happy with the quality.
    In SD I don’t bother with ProRes as uncompressed SD is easy to manage. The only catch is that Color leaves the field order as lower in the uncompressed or ProRes file which is a nuisance in PAL, but easily corrected with a flip field filter on all shots.
