Activity Forums Adobe After Effects Quick question about expression
  • Quick question about expression
    Posted by Maxime Marquis on August 25, 2009 at 3:50 pm
    I’m color correcting a music video which mainly consists in two different scenes intercutted (the band playing and a fiction part, I know how original!). All the edited footage is in one sequence.
    I used an adjustment layer with the appropriate corrections and keyframed the opacity (0 or 100) so it fits with one of the scene (the band). Now I want to do the same with another adjustment layer for the other scene(fiction). The opacity will be the exact opposite of the first layer. (0 when 100, 1 when 99…). What expression can I use so I won’t have to keyframe the second adjustment layer?
    Thanks in advance
    Maxime Marquis replied 17 years ago 3 Members · 4 Replies
  • Jon Geddes
    August 25, 2009 at 4:44 pm
    Just create an expression for the opacity of adjustment_layer_2 that says:
    100 – opacity of adjustment_layer_1
    obviously you will have to enter the proper syntax but I’m assuming you just wanted to know the logistics of the expression.
    Jon Geddes
    http://www.precomposed.com
  • Roland R. kahlenberg
    August 25, 2009 at 5:03 pm
    The Interpolation method works well here.
    Apply the following expression to the second Adjustment Layer’s opacity property. Stuff in [ … ] are instructions for you to follow.
    //Start script
    AdjOpq = [pickwhip to the first Adjustment Layer’s opacity];
    linear(AdjOpq,0,100,100,0)
    //End Script
    HTH
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
  • Jon Geddes
    August 25, 2009 at 5:05 pm
    That would also work.
    Jon Geddes
  • Maxime Marquis
    August 26, 2009 at 2:21 am
    Thanks guys, I tried Jon’s way and it worked perfectly. Saved me a lot of time!
