Activity › Forums › Adobe Premiere Pro › Quick Question
  • Quick Question
    Posted by Chuck Obernesser on April 4, 2009 at 1:06 pm
    I’ve used FCP for 7-8 years now. I started a new business that has a great deal of video for the web. I want to speed up the work flow. Does Premiere export FLV files right out of it or do I have to send the final project to another app? Also has anyone ever used fcp and Premiere. Is there a big learning curve to it?
    Thanks for all and any help
    Chuck Obie
    David Dobson replied 17 years, 5 months ago 4 Members · 3 Replies
  • Eddie Lotter
    April 4, 2009 at 3:15 pm
    [Chuck Obernesser] “Does Premiere export FLV files”
    Yes, see Exporting for the web in the PPro Help for details.
    [Chuck Obernesser] “Is there a big learning curve to it?”
    The fundamentals of video editing are the same, but PPro’s approach is different from FCP.
    You will find links to many free tutorials in the PremiereProPedia that will quickly show you how things are done in Premiere Pro.
    Cheers
    Eddie
  • Lucas Windsor
    April 4, 2009 at 3:22 pm
    In Premiere Pro CS4 when you hit export it brings up a dialog box that allows you pick all your rendering settings. Once you hit OK it brings up your project in Adobe Media Encoder. This is a different program, but it works seamlessly. It allows you to keep working while rendering.
    I have worked with both editing suites and there is some new things to learn between the two, but overall they have a similar enough feel that migrating from one to the other shouldn’t be a big issue.
  • David Dobson
    April 4, 2009 at 3:39 pm
    I switch back and forth regularly.
    The only really frustrating part about the switch is all the keyboard shortcuts being slightly different.
    Basic editing is the same in any system – it’s all the tricks and shortcuts and special things that you did FCP that you’ll have to relearn in PPro that will make you wish you hadn’t switched. Get past that before you give up on it. Ppro does some things much better than FCP….things you might not even think of trying since they don’t exist in FCP (and vice versa).
    Also, PPrp exports to .flv and .f4v directly.
