Activity Forums Adobe After Effects Quick Question
  • Quick Question
    Posted by Matt Luckey on June 4, 2006 at 1:00 am
    I just noticed I did most of a project in “Front” view and not “active camera.” So when it renders it renders it in the active camera view but its all screwed up. Is there anyway to render in “Front view?” Thanks.
    Ephraim Jones replied 20 years, 3 months ago 2 Members · 2 Replies
  • Ephraim Jones
    June 4, 2006 at 11:51 pm
    Assuming you haven’t put any cameras in your composition and animated them, you can add a camera layer (a default one should work). The camera will be the same view as the active view, so you will have to adjust the camera so that it frames the scene the way you want it. AE will always render the active camera, which in this case will be the one you added.
  • Ephraim Jones
    June 5, 2006 at 4:11 pm
    Just to clarify what I wrote, when you add a default camera (usually 50mm) it frames the scene as it appears in the active camera view. If you’ve resized or moved any 3d layers you may have to adjust the camera you added using the camera tools. Just select the camera in the composition view menu and adjust. This will now be the active camera view.
