Activity Forums Apple Final Cut Pro Legacy Quick Nattress Standards Conv ?
  • Quick Nattress Standards Conv ?
    Posted by Rich Rubasch on May 31, 2007 at 3:44 pm
    If I drop an NTSC clip into a PAL sequence and apply the G Convertor everythng works great. However, is it correct that I have to use FCP BasicMotion settings and scale the source clip to 120% to fill the PAL frame? It doesn’t mention scaling the image manually with FCP BasicMotion settings to get it to fill the screen. If I don’t it is not filling the screen.
    Also, from NTSC to PAL I notice a slight gamma shift making the PAL clip a bit darker than the source. Compressor makes a PAL clip with its Advanced Conversions very quickly and not gamma shift and 1/8 the processing time. Looked pretty good to me and compressor did the scaling.
    Rich Rubasch
    Tilt Media
    Graeme Nattress replied 19 years, 3 months ago 5 Members · 9 Replies
  • 9 Replies
  • Rich Rubasch
    May 31, 2007 at 3:50 pm
    also, Nattress makes a 25fps clip (QT Player clip info) whereas compressor makes a clip that says it is 24.98. Is it 25 or 24.98?
    Rich
  • Bouke Vahl
    May 31, 2007 at 4:34 pm
    Qt player clip speed info is notorious, well, strange…
    I would not think about it too much.
    If you want to be sure, capture some footage with BITC (put it in the top or you will have strange readings) and see what it really does.
    Last but not least, if it looks good, it is good.
    Bouke
    http://www.videoToolShed.com
    smart tools for video pro’s
  • David Roth weiss
    May 31, 2007 at 4:38 pm
    Send your question to Graeme, he’s a pretty quick responder.
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Rafael Amador
    May 31, 2007 at 5:09 pm
    Rich,
    Compressor can do it fast if you set the Frame Control “off’ or “automatic”, but for a good standard conversion I think you should set it in Custom. And that mean ages waiting for the process to finish. You can do it in Shake too (Timing>Convert) and the result is very good, but Compressor and Shake use the same engine and are the same slow.
    I heard of people converting with MPGStreaclip. It seems do it well.
    Cheers,
    tafael
  • Graeme Nattress
    May 31, 2007 at 7:00 pm
    You can scale by hand, or if you use the nesting method, the plugin will scale for you! Video here: https://www.nattress.com/Products/standardsconversion/movies.htm shows the nesting method.
    I’ve never seen a levels shift inside FCP. Which codecs are you using?
    Compressor, when I last tested it took about 40 times longer to render a conversion that looked better than the plugin. I’m sure they’ve made it faster since then, but not by that much 🙂
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Rich Rubasch
    May 31, 2007 at 9:07 pm
    I got it on the scaling thing. Thanks.
    Using DVCPro50 clips and each time I render it with Nattress the clip gets darker. Compressor is an exact match luma wise.
    Rich Rubasch
    Tilt Media
  • Graeme Nattress
    May 31, 2007 at 9:28 pm
    That’s so weird. I’ve never seen it get darker. Have you got a BMD card installed?
    Graeme
  • Rich Rubasch
    May 31, 2007 at 10:19 pm
    I did the test with 5.1.4 on a dual 1 gig G4 with a Pipe Studio card.
    It made a shift in both directions making the clip darker.
    The Pipe has never had this issue in other types of converting/rendering. But I can’t rule out operator error either!
    Rich Rubasch
    Tilt Media
  • Graeme Nattress
    June 1, 2007 at 1:22 am
    If you just put an NTSC clip in the PAL timeline and render (without my plugin) do you get the same shit?
    Graeme
