Activity › Forums › Maxon Cinema 4D › quick mograph question
  • quick mograph question
    Posted by Simon Roughan on May 8, 2013 at 9:17 am
    Is it possible to get the sound effector to effect the number of clones?
    thanks
    Simon
    You know I’m born to lose, and gambling is for fools, but that’s the way I like it, baby. I don’t want to live forever!
    Simon Roughan replied 13 years, 4 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    May 8, 2013 at 3:35 pm
    Yes, there’s at least two ways to do it:
    1. All MoGraph — Blend between cloners:
    In this method you create a cloner that represents the low clone count and duplicate it, setting the clone count to the maximum number you want. Then you put both of them in another cloner set to blend mode. Apply the sound effector to this clone and in the parameters tab turn “modify clones” up to 100%.
    Example: 5977_sound2clonecount.c4d.zip
    2. MoGraph + Xpresso:
    With this method you create an Xpresso expression with four nodes. Drag in the sound effector and connect its object port to a mograph>Data node’s object in port. Add an out>strength port the data node and connect it to a range mapper. Adjust the range mapper parameters and connect it to the cloner’s clone count in port.
    Example: 5978_sound2clonecountxpresso.c4d.zip
  • Simon Roughan
    May 8, 2013 at 3:57 pm
    Cheers Adam, that’s exactly what I was looking for. Ta!
