Activity Forums Apple Final Cut Pro Legacy quick letterbox question
  • quick letterbox question
    Posted by Rob Gutermuth on June 30, 2015 at 1:38 pm
    Hi All,
    Here is hopefully a quick and easy one…
    multi cam shoot – one of my main cameras was not level when it was recording. So, I added 1 degree of rotation in the motion tab. Fixed that.
    but when I view that clip on a 4×3 TV as 16×9, the top of the letterbox is a little “jagged” instead of straight…
    is there a simple way to correct this with any clip that I rotate like that? my first thought was to just zoom the clip by like 105 percent or something just enough to hide that? or is there a better way?
    Rob Gutermuth
    Media Creations
    Nick Meyers replied 11 years, 2 months ago 4 Members · 3 Replies
  • Shane Ross
    June 30, 2015 at 6:30 pm
    Your first thought is correct. Zoom.
    Shane
    Little Frog Post
  • Greg Ball
    June 30, 2015 at 8:23 pm
    Zoom is the way.
  • Nick Meyers
    July 1, 2015 at 10:45 pm
    yes, zoom will hide the issue,
    ALSO
    you should set the sequences motion filtering to BEST
    this will improve the quality of the rotation once it is rendered
    you do this in the sequence’s settings, in the video tab.
    nick
