Activity › Forums › Apple Final Cut Pro Legacy › Quick jumps appear in three minute pan of an extremely long image
Jeremy Garchow replied 16 years, 5 months ago 5 Members · 13 Replies
Jeremy Garchow
April 7, 2010 at 5:14 pmThey would probably both be the same, the trick is not a motion track, but rather velocity at which it travels. So, how may chunks do you have, how big (pixels) is each chunk and how long do oyu want the move to last?
Once you figure that out, you take each chunk, make it move a certain amount of time, and then add on each chunk so that each chunk gets the exact same amount fo time and starts and ends at the same place in the active area of the screen. This will ensure that each chunk is moving at the same velocity.
Mark Suszko
April 7, 2010 at 7:20 pmOr try grouping groups of groups. So that you control one master group, in Motion.
Don’t try reading that sentence in a mirror, though.
Jeremy Garchow
April 7, 2010 at 7:21 pm[Mark Suszko] “Or try grouping groups of groups. “
Just as long as the group isn’t over about 4k wide. AE has a little more leeway in this regard.
Jeremy
