Activity Forums Adobe After Effects quick interface question
  • quick interface question
    Posted by Shane Robinson on June 22, 2010 at 8:00 pm
    Quick question about interface: What does it mean when AE throws a pair of brackets around the name of a comp in the timeline panel? Is it an indication of transparency, parenting, nesting, trackmat or something else? Thanks for your reply.
    Shane Robinson replied 16 years, 2 months ago 2 Members · 2 Replies
  • Todd Kopriva
    June 23, 2010 at 12:30 am
    You can toggle between showing the source name and the layer name. The brackets are an indication that you’re seeing the default layer name, which matches the source name.
    See “View and change layer information”.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Shane Robinson
    June 23, 2010 at 3:36 pm
    Great, thanks, that was exactly what I was wondering. Much appreciated.
