Activity Forums Adobe After Effects Quick Expression Question
  • Quick Expression Question
    Posted by Lukeinvt on July 28, 2005 at 7:00 pm
    Hello all, need a quick tip on expressions (AE 5.5)
    I have about 50 photoshop layers, each a different coin. At the end all 50 coins cover the entire TV frame .
    What I want is the coins to appear in succession, the bottom most first.
    Each new coin should appear every 10th frame, about 3 per second, so about 16 seconds total.
    Of course I could .laboriously move each coin to the correct starting point, but that takes forever, there must be a better way.. My rather limited knowledge of expressions tells me I would have to apply the expression to each photoshop layer, so this may be just as tedious.
    Any help would be appreciated
    Filip Vandueren replied 21 years, 1 month ago 2 Members · 1 Reply
  • Filip Vandueren
    July 29, 2005 at 12:24 am
    Check out the “sequence layers command” if you set a large enough value for overlap you’ll get the staggered starting points you’re looking for.
