Activity › Forums › Apple Final Cut Pro Legacy › Quick cross platform question
  • Quick cross platform question
    Posted by Chris Holland on April 8, 2009 at 6:21 pm
    Hello all,
    I was trying to get a couple of clips from FCP to another computer for use in after effects. Now the person who is doing the After effects work is using a PC. I exported the clips from my time line as quicktime conversion, HDV 1080 codec, which is what i usually do when exporting to quicktime. These clips did not play back at all in the AE on the PC. However if I saved the clips as full quality AVI the clip goes from 35mb to 900mb! Which is to big to get across on-line.
    Is there any way to get the PC to play the QT clip?
    Any help would be greatly appreciated. thanks in advance.
    Chris
    Rafael Amador replied 17 years, 5 months ago 3 Members · 4 Replies
  • Rafael Amador
    April 8, 2009 at 7:06 pm
    Hi Chris,
    You can export as Proress. your PC guy will only need the free ProRess reader for Windows and QT Pro.
    Rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Chris Holland
    April 8, 2009 at 8:05 pm
    Thank you Rafael 🙂
    Is that the standard to export things out uncompressed? Rather than export out at current settings?
    Chris
  • Curious Turtle
    April 8, 2009 at 8:52 pm
    Just to let you know, the guy working on the Windows box won’t need QT Pro to work with ProRes. Just the decoder and regular QT Player installed will work fine.
    There is no “standard” when it comes to transfering files across for further work. Each workflow will be slightly different. You’re trying to balance three things here – compatibility, quality and file size. Uncompressed files will help you maintain the first two (with caveats about colour bit depth) but create large files. Apple ProRes gives a good trade-off about maintaining quality whilst giving manageable filesizes.
    On the way back from the Windows machine, you might want to consider Uncompressed or a high-quality PhotoJPEG. You can’t render back out to ProRes on Windows.
    All the best,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Rafael Amador
    April 9, 2009 at 2:19 am
    Just to add to the comments of Ben, you can also use the AVID codecs. You can get them free for MAC and PC in the AVID web site.
    From my view the best option when working cross platform is “Sheer”.
    Have a look in https://www.bitjazz.com
    Rafael
