Activity Forums Apple Final Cut Pro Legacy quick audio question
  • quick audio question
    Posted by Brian Pitt on December 20, 2005 at 9:52 pm
    I have an audio file that I am adding into my project and it is requiring rendering before it will play back. Once I render the file, it sounds a bit off…as in a little bit of popping and distortion. Any ideas what the problem could be?
    Brian
    Brian Pitt replied 20 years, 9 months ago 3 Members · 3 Replies
  • Jeff Carpenter
    December 20, 2005 at 10:13 pm
    Go out of Final Cut and find the file itself. Open it up in Quicktime Pro and re-save it with settings that match your project and sequence. Then re-import that new file and just use that.
  • Mark Maness
    December 20, 2005 at 10:16 pm
    It sounds like its an mp3 file…. if so, you need to convert it with Quicktime or iTunes first. Either way, you’ll need it to match your sequence settings.
    _______________________________
    Wayne Carey
    Schazam Productions
  • Brian Pitt
    December 20, 2005 at 10:21 pm
    thanks. that fixed the problem!
    Brian
