Activity Forums Avid Media Composer Quick Audio db adjustments like in FCP?
  • Quick Audio db adjustments like in FCP?
    Posted by Jerry Sneede on January 29, 2015 at 4:10 pm
    Is there a way to do a quick audio adjustment on a track with a keyboard shortcut like in FCP (where you can map raise/lower 1 or 10 db to a key)
    Jerry Sneede replied 11 years, 7 months ago 2 Members · 2 Replies
  • Olivier Prudhomme
    January 29, 2015 at 4:56 pm
    Coming from FCP I miss this feature a lot.
    If you’re on MC 7.0 at least you can now have access to a shortcut to add or remove gain.
    You have to turn on the feature first and then you’ll see a little icon in the lower left corner of the audio clip. Clicking on it will reveal a slider so you can lower/raise the volume.
    But don’t get too excited! If you work with dual mono tracks (L-R) you’ll have to set the gain for each track…
    So not as quick as FCP but faster than before.
    I also just came across a post saying that there was a keyboard shortcut that I haven’t tested yet. But it seems it applies the effect to the whole track
    ALT(OPT) + SHIFT + Arrow UP/DOWN adjusts Clip Gain in Timeline
    (when Clip Gain is visible in timeline settings & Track selected)
    Los Angeles – TV Promo Editor – FCP – AVID
  • Jerry Sneede
    January 29, 2015 at 7:16 pm
    Yes! That works, ALT Shift Arrow does the trick. Thank you.
