Activity Forums Blackmagic Design Quick ATEM Television Studio
  • Quick ATEM Television Studio
    Posted by Steve King on June 28, 2012 at 6:42 pm
    I need to uplink to Sat a feed to Europe. The soiurce has to be SD NTSC 4:3 but the download clients in Europe want sd 16:9. Can I set up a 16:9 SD project on the atem and use a gfx as background and key the 4:3 image in the center? Maybe logo on either side of the 4:3 element? Then send this out put from ATEM TV studio to the sat truck?
    Steve King
    AVS Media Group
    Andreas Wojtaschek replied 14 years, 2 months ago 3 Members · 2 Replies
  • Roger Suski
    June 28, 2012 at 10:19 pm
    I don’t believe the ATEM TVS has a DVE. You’d need one to scale the 4×3 down to make room for the bars.
    If you had an ATEM 1ME, would be possible.
  • Andreas Wojtaschek
    June 29, 2012 at 7:46 am
    You could do this if you get the 4:3 signal as a pillarbox 16:9 signal. Then you could use an upstream key to remove the bars and place a logo there. You can’t do this inside TVS because there is currently no way of resizing or squeezing an input inside the TVS.
    Have in mind that the multiview is currently not capable of displaying an SD 16:9 signal. It will show a squeezed 4:3 pillar box picture instead.
    Regards
    Andreas
    Entertainment Producer IHK
    mindandvision
