Activity › Forums › Apple Final Cut Pro Legacy › Quick aspect ratio question
Posted by Jonathan Young on February 28, 2013 at 3:06 amI am taking a 1920×1080 video and compressing it to 640X360 the client wants the settings to be 16:9 anamorphic when I add this in compressor it turns it into 540X360 after it compresses it looks fine but has a green vertical bar (the height of the player) on the right side of the player..
what is wrong?
thanks for everyones helpRafael Amador replied 13 years, 2 months ago 3 Members · 4 Replies -
Jonathan Young
February 28, 2013 at 5:33 amOk that worked but why when I choose the 720X480 (another final output that the client wants from the 1920X1080 master)if I use the square pixel option for aspect ratio the final video comes out looking more 4:3 but when I add the 16:9 anamorphic setting to the aspect ratio it comes out looking fine. but when I add the 16:9 anamorphic setting to the aspect ratio of the 640X360 I get the video that turns into 540X360 with the green vertical bar on the right hand side of the player?
What I am trying to say is why does the 720X480 have to have a 16:9 anamorphic pixel aspect ratio to come out correct but the 640X360 have to have the square pixel aspect ratio to come out correct.Thanks
Nick Meyers
February 28, 2013 at 10:35 amlook at the numbers
640×360 is a 16/9 ratio
720×480 is 4/3, so needs non-squre pixels
nick
Rafael Amador
February 28, 2013 at 12:46 pm[jonathan young] “What I am trying to say is why does the 720X480 have to have a 16:9 anamorphic pixel aspect ratio to come out correct but the 640X360 have to have the square pixel aspect ratio to come out correct.”
720×480 is made of NTSC PIXELS.
If you check “Anamorphic”, it will be 16×9.
If you don’t check Anamorphic, it will be 4×3.Think of the pixels as tiles.
NTSC pixels, NTSC Anamorphic pixels and Squared pixels, all have different shapes/proportions.
NTSC and NTSC Anamoprphic are rectangular. Squared are squared.[jonathan young] “when I add the 16:9 anamorphic setting to the aspect ratio of the 640X360 I get the video that turns into 540X360 with the green vertical bar on the right hand side of the player?”
If you check Squared pixels as Anamorphic, you are distorting the pixels. They won’t display Squared any more.
Squared pixels are just that “Squared”. No option for Anamorphic.
rafael
