Activity › Forums › Maxon Cinema 4D › Questoin for multipass shadow for After Effects.
  • Questoin for multipass shadow for After Effects.
    Posted by Josh J. johnson on July 16, 2008 at 7:56 pm
    I tracked a aerial shot with syntheyes worked great. Brought into cinema added some 3d elements and shadows. I have a plane for my floor so you can see the shadows. I applied my background to the plane along with a compositing tag “not seen by camera” and “compositing bg” on.
    I can’t seem to make it work in AE? I can say just render out the whole image in Cinema with the backdrop and everything looks fine but then I can’t isolate things in AE.
    Any help would be greatly appreciated. I searched the forums and I think I did everything that was suggested. Also I can do this in photoshop with no problems. In photoshop I just cut out my elements with their alpha place them on my photo bg and add shadow pass on top with multiply blend.
    So basically I can get my stuff in AE and everything tracks perfect looks great but I have no shadows?
    thanks
    Kevin Snyder replied 18 years, 2 months ago 3 Members · 5 Replies
  • Adam Trachtenberg
    July 16, 2008 at 8:36 pm
    I don’t understand why you aren’t able to do it the same way in AE that you’re doing it in PS.
  • Josh J. johnson
    July 16, 2008 at 10:39 pm
    Hey Adam thanks for the reply. It seems everything works minus the shadow on the ground?
    I tried the exact same setup I did in PS with no luck. I tried the ground plane(shadow catcher) with seen my camera on and off.
    Josh Johnson
    Manager of Video Production
    ETC, Inc.
  • Josh J. johnson
    July 16, 2008 at 10:48 pm
    In ps I would extract my elements put them together then add the shadow pass on them not the same with AE?
    thanks again
    Josh Johnson
    ETC, Inc.
  • Josh J. johnson
    July 17, 2008 at 6:18 am
    Here is a picture Adam to better show my problem. As you can see my shadow catcher is all white? How and why I ask lol. What I’m expecting to have is my shadow catcher be invisible besides the shadows? I tried nearly every option that I can think of.
    Josh Johnson
    ETC, Inc.
  • Kevin Snyder
    July 17, 2008 at 4:07 pm
    Try changing the white layer with the shadows transfer mode in AE to Screen or Multiply.
    KMS
    love
