Activity Forums Apple Final Cut Pro Legacy Questions – Soundtrack Pro
  • Questions – Soundtrack Pro
    Posted by Tom Laughlin on August 3, 2010 at 4:13 pm
    Creative Cow Users,
    Thanks for your emails and continuous support.
    I’m a little new to audio sweetening, and I had a few questions about using Soundtrack Pro (STP):
    1.) When do you normalize in FCP? And how do you do it? How does John do it, the same way?
    2.) When do you normalize in STP? And when you do, what “db” do you use to normalize it to? (see 1st pic)
    3.) When you take out noise, you mean, do you take out room tones or pops or cracks? Do you use the analyze filters in STP, and analyze whole clips or just audio where needed?
    4.) Do you automatically take out certain aspects of audio even before you begin editing, or do you work on audio more after you lock down the rough? I’ve chopped up some interviews, so should I analyze the whole clip and replace the whole clip’s audio or do it in stages and only where needed?
    5.) Do you use any of the pop, click, or DC offset filters, and if so, how strict are you on those?
    Tom
    Tom Laughlin
    Producer/Editor
    Salt Lake City, UT
    FCP7/Sony EX-3/Mac Quad-Core Intel
    Rob Grauert replied 16 years, 1 month ago 2 Members · 1 Reply
  • Rob Grauert
    August 3, 2010 at 4:58 pm
    I’m not an audio expert, but I may be able to help.
    “When do you normalize in FCP? And how do you do it? How does John do it, the same way? “
    I believe the point of normalization is to bring the loudest sound up to a desired level. So if you’re audio is low, and the loudest sound is at -20dB, maybe you want to normalize it to -6dB. You can do this to a large number of clips so that they all peak at the same level.
    How to do it? Select the audio clip, Modify > Audio > Apply Normalization Gain
    “When do you normalize in STP? And when you do, what “db” do you use to normalize it to?”
    It’s the same concept concept as FCP. You’re raising the audio levels of clips so they all peak at the same level. As for when to do it? It’s the first thing I do. Then I do Compressor/Limiter, noise reduction, high pass and low pass filters, and EQ.
    I do audio after I’m done cutting the story together. Picture should be locked before you do audio
    I’ve used the pops/clicks filter before. It works Ok. I’ve never used the other ones before though. Not for any particular reason. I just don’t think I ever needed ’em. I’d read the manual and see what they’re for if you’re interested.
    Hope that helps some.
    Rob Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
