Activity Forums Apple Final Cut Pro Legacy Questions – Editing SD and HD together
  • Questions – Editing SD and HD together
    Posted by Tom Laughlin on August 24, 2010 at 2:24 pm
    Creative Cow Users,
    Ok, I’m editing in FCP, I have two sources of video, one that is 1440×1080 60i, 29.97, and it was shot HDV in the EX-3, and so my base time-line resolution is 16×9, but most of my cutaways are in DVC-Pro 50, or 4×3, 720×480. So, what I want to do is try and make the SD look as good as the HDV video or 16×9 video, so what I’ve done in the past is taken the 4×3 image, and dragged the image to be larger, so it fills the 16×9 window (upscale), then re-framed it, so it completely covers the frame, so I eliminate black bars on the sides, as well as adding a “sharpen filter” and do some extra color correction, to make the colors pop a little bit more. Now, I’m not saying that this is the best way, but now with a new project underway, I’m in a time-crunch, and most of my cutaways are in 4×3, what should I do, and what other ideas do you have with this, making SD look like HD? Or what you’ve done in the past.
    Tom
    Tom Laughlin
    Producer/Editor
    Salt Lake City, UT
    FCP7/Sony EX-3/Mac Quad-Core Intel
    Michael Gissing replied 16 years ago 3 Members · 2 Replies
  • Zane Barker
    August 24, 2010 at 2:56 pm
    For starters you never told us what your time line setting are. Your time line settings are key to preserving quality.
    Enlarging 4×3 SD video (I’m assuming DV codec) to HDV size is going to look horible. So I recommend editing it in a SD time line and I recommend you use the pro res codec as DV is not so good at maintaining quality.
    In the future save your self a few extra headache and have both your cameras shoot the same format, frame size and frame rate.
    **Hindsight is always 1080p**
  • Michael Gissing
    August 24, 2010 at 9:50 pm
    SD footage from Digi/SP beta or DV gets recaptured via SDI and upscaled to 1920 x 1080 ProRes 422 via my Kona3 card.
    Not everyone has Kona and SDI capable SD machines but as I grade and online, it is a simple task to recapture just the SD material after media managing the final timeline. You could wait until the locked off edit to do the same.
