questions about using .mpg file
I need to make a dvd out of a .mpg file. When I drop the clip into Premiere 6.5, the audio plays fine but the image seems to play at a lower frame rate in the preview window. This is the same no matter what i export to as well. Do i need to convert the file back to .avi before rendering to dvd in Premiere?
Here’s the file specs:
Duration: 3min 36sec
Average Data Rate: 262.66KB/second
Image Size: 320×480
Pixel Depth: 0 bits
Frame Rate: 29.97 fpsAudio: 44100 Hz – 16 bit – stereo
-Russ
