Activity Forums Maxon Cinema 4D Questions about using alpha image
  • Questions about using alpha image
    Posted by Richard Holst on April 18, 2007 at 11:30 pm
    I am new to Cinema 4 D (I have Studio Bundle R10 on Mac) and I have run into some trouble with my material texture.
    I have a lot of experience with alphas in other applications so i have made a fairly clean version in Photoshop (maybe I am not). I brought it in as a native file (PSD) with a normal alpha, I did not create a channel alpha. My first question is… what is the best advice on what file type to bring in? This worked more or less but is there a preferred type?
    The first trouble I had was a thin white halo along the edge of the cutout image. I do not encounter this very often but have dealt with it before by laying a thin dark line at the edge. I would prefer to avoid this as it more than likely look cartoony in this case. The next question, is there a setting that I am missing to eliminate this artifact?
    Also, I do not want the cube to be visible at all but I am getting a thin line at its edge. I created a completely transparent material and laid it on below the guy but I am still
    Richard Holst replied 19 years, 5 months ago 3 Members · 3 Replies
  • Brian Jones
    April 19, 2007 at 1:27 am
    -put the psd in the alpha channel too. (tiff or psd both good, both same rules)
    -the thin line on the edge is usually caused by antialiasing and that’s a whole subject in itself
    -cube?
  • Ronaldo Montalvo
    April 19, 2007 at 6:32 am
    in c4d 10 it seems to work cleanly by just putting the same photoshop cutout/still in the color and the alpha channel as brian mentioned. i had problems with this alpha fringe in C4D 9 with some photohop art. maybe check this:
    https://forums.creativecow.net/readpost/19/857860?
  • Richard Holst
    April 19, 2007 at 2:45 pm
    Thanks guys. Oddly part of it went away on the edge of alpha when I applied a bump.
    Stillgetting a bit at top edge of ‘portrait’ object, which I have now changed to a plane object.
    Lots of settings in anti alias any thoughts on which to goose to remove the line?
