Activity Forums Adobe Premiere Pro Questions about exporting LONG projects – DVD quality
  • Questions about exporting LONG projects – DVD quality
    Posted by Martin Albrecht on September 22, 2008 at 1:22 pm
    Hello everyone,
    I would appreciate someone’s comprehensive advice to my query, as i have been looking through the topics, but wasnt able to either find or understand the answer.
    I finished a project 2hours in duration. I’m trying to export it to DVD with the best possible settings. The default selection was PAL High qual, VBR 4mps if i remember correctly, and the size predited was over 5GB, but with maximize bitrate window ticked it was just small enough to fit a DVD. After hours of transcoding :-), the quality was quite poor when viewed on plasma. Picture was grainy and jittery.
    My question 1. is – How do i export a 2 hour movie in close to professional quality? is there another way, like exporting it to an avi format (probably getting something like 50GB file) and them shrinking it somehow? Or what settings should i use? What’s interlacing and does it have an effect?
    Ok, i know this is more then one question.
    my 2nd area of questions concerns DVD menu. I have markers in the desired spots, but is there a way i can create a menu, post export, if i dont have Encore?
    Thank you very much for your answers. If you need additional detail in order to answer, i’d be happy to provide them, i just didnt want to flood you in too long a question.
    I’m using premiere pro 1.5
    Marty
    Jim Leonard replied 17 years, 11 months ago 3 Members · 6 Replies
  • Vince Becquiot
    September 22, 2008 at 4:12 pm
    First, 2 hours on a standard DVD is not going to look very good no matter how you slice it. (Unless you know someone well placed in hollywood and your footage was shot on film)
    The way around it is to use dual layer DVDs, which nearly double the recording time. There are a few caveats however.
    First you need a dual layer capable burner. Second, the media is much more expensive. Third, the “home burned” DVDs are quite unreliable compatibility wise, and finally, there is often a small glitch as the laser switches to the second layer.
    Still, to get the best quality on a single layer DVD, be sure to use a bitrate calculator, there are plenty of those online.
    Cheers,
    Vince Becquiot
    Director | Editor
    Kaptis Studios
    Santa Rosa, CA
  • Martin Albrecht
    September 23, 2008 at 11:02 am
    Thanks Vince,
    I tried to play around with exporting the project as mpg file regardless of the size – and the encoder in PP calculted approx 1.02 MB per second in the best quality, which would make the file around 7.5GB large, which i could live with and maybe then shrink it in Encore somehow or in som other way.
    Regardless, I came across seeminlgy an unsurmountable problem – whenever i let it encode, it comes up with an “Unknown Error” straight away. Doesnt even start transcoding. When i try the same settings on a smaller shorter project, no problem. When i try it on the current big project, chop most of it off and leave just 4 minutes, it still wont do anything and come up with an error straight away. Any ideas what may be wrong? Has anyone had and “unknown error”?
    Thank you kindly
  • Vince Becquiot
    September 23, 2008 at 3:31 pm
    Try this calculator:
    A 2 hour DVD would require VBR 2 pass, with something around 8 Max, 3.4 Average, and 1.3 MB/s Min.
    I don’t know about the error, that could be a whole different thread.
    You could also export as Quicktime animation 100%. (2 hours will be around 120 Gigs), then let Encore do an auto encoding. The Quicktime export from Premiere will be a lot faster than the Mpeg2 export and you won’t lose any further quality, which you can’t afford on a packed DVD.
    Vince Becquiot
    Director | Editor
    Kaptis Studios
    Santa Rosa, CA
  • Martin Albrecht
    September 25, 2008 at 4:14 pm
    Hey there Vince,
    I have followed your advice and sure enough, PP stared encoding, went on for several hours and when it got to the end, it came up with:
    “error compiling movie. Unknown error”. It is the same message that comes up when i try to use the adobe encoder. I cant think why it does it with this proect and not with others. I only use a few titles, some mp3 music and footage from a dv camera captured through PP. There are 2 pieces of footage that are different – ultrasound of a baby, that i only imported and dont know how it was recorded. Could this be the reason?
    Also, i realised that i kind of hijacked my own topic. should this be a new thread?
    Thank you very kindly for your advice,
    m.
  • Martin Albrecht
    September 25, 2008 at 4:23 pm
    One more note – after reading up on the same problem elsewhere on this forum, i’d like to point out that the EXPORT TO DVD function WORKED and the movie is successfully burnt to a DVD. only after seeing the poor quality i tried different format of exporting and that’s when the error started coming up. I have not changed a single thing since successfully exporting to DVD.
    Thank you very much again.
    m.
  • Jim Leonard
    September 26, 2008 at 12:44 am
    If you’re having trouble exporting directly to MPEG-2, try exporting to Movie first (ie. render out your timeline to one large clip), then double-click the clip, THEN try your media encode to MPEG-2. I remember having this problem with 1.5 and that’s how I got around it.
