Activity Forums Adobe After Effects question; when using timewarp
  • question; when using timewarp
    Posted by Bret Latter on April 13, 2008 at 3:23 pm
    I have a sequence of targa files I imported as multi files>targa sequence. When laying them on the timeline the length is 54 seconds. I am just trying to slow down the motion of the sequence by using timewarp. The problem I’m having is it only outputs a total of 54 seconds total then stops. The length is 54 seconds at one picture =’s one frame. The length after slowing it down will be longer than the original 54 seconds, but I am unable to get it to render the whole sequence.
    I hope I explained this well. Any help would be appreciated.
    thanks,
    bret
    I am using AF 7.01 pro
    Bret Latter replied 18 years, 5 months ago 2 Members · 2 Replies
  • Harrison Willett
    April 13, 2008 at 7:29 pm
    I am not completely sure what you are trying do. I usually use “time remapping” (Ctrl + Alt + t on PC) with sequences to stretch their length in a comp. That may help you achieve the effect you want. Hope that helps.
  • Bret Latter
    April 14, 2008 at 3:59 am
    Thanks, that worked great.
    bret
