Activity Forums Adobe After Effects Question to Make a Ghost Trail
  • Question to Make a Ghost Trail
    Posted by Raymond Tuquero on May 24, 2007 at 8:44 pm
    Hello everyone
    I was just wondering if anyone can tell me a “How TO” on making Ghost Trails or some sort of trail after an object. I am trying to Move a logo across a screen with some sort of Trail / tail following it. All in After Effects 7.0.
    Raymond
    Darby Edelen replied 19 years, 4 months ago 5 Members · 8 Replies
  • 8 Replies
  • Enrique Borja
    May 24, 2007 at 8:50 pm
    try with the echo effect( i think is called like that), maybe it could be what you need
  • Christopher Noll
    May 24, 2007 at 8:51 pm
    Echo Time in the layer/time menu Your footage must have the motion pre-comped to use this.
    C
  • Raymond Tuquero
    May 24, 2007 at 8:55 pm
    Now I tried the Echo Time set up and all I get is my logo turns into a brighter color of itself…I think I am missing something there…
    Thanks guys by the way.
    -Raymond-
  • Jason Sanders
    May 24, 2007 at 9:01 pm
    you could always:Take your object thats in motion
    >duplicate the layer>mask around the object if needed>drag the duplicated layer one frame forward>bring the opacity down or change the mode(screen, add ,etc). and another option is playing around with echo and time displacement. i have made things work using this method, although there is probably a more precise approach to this effect, this is what i have used. hope i could help. GL
    Jason Sanders
    http://www.hecticfilms.com
  • Enrique Borja
    May 24, 2007 at 9:11 pm
    [Anti_M] “Echo Time in the layer/time menu Your footage must have the motion pre-comped to use this.”
    mmm i was close!! hehe thats what i meant
  • Christopher Noll
    May 24, 2007 at 9:15 pm
    That’s the typical look of the echo time preset. You need to change the number of echos to more than 1 and the adjust the Echo time setting depending on the length of the comp.
    BTW I was so wrong…EchoTime is in Effects/Time…DUH!
  • Jason Sanders
    May 24, 2007 at 9:22 pm
    i would also add some blur , glow then drop opacity
    Jason Sanders
  • Darby Edelen
    May 24, 2007 at 9:39 pm
    [draken182] “i would also add some blur , glow then drop opacity”
    Good suggestions, depending on the look you’re going for you could also add some large blurry plasma/dust particles to emit from the layer.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
