Activity Forums Adobe Premiere Pro question – sound on right chanel, duplicate
  • question – sound on right chanel, duplicate
    Posted by Suzin Daly on July 31, 2015 at 7:57 pm
    I only have sound on the right channel – Is there a way to duplicate the right channel onto the left channel.
    Suzin Daly replied 11 years, 1 month ago 3 Members · 3 Replies
  • Ann Bens
    July 31, 2015 at 11:37 pm
    Sounds wrong but Fill right.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Ryan Frias
    August 1, 2015 at 2:44 am
    Does Premiere let you pan the right channel to the Center?
  • Suzin Daly
    August 1, 2015 at 11:39 am
    I do not know if PP lets for pan right channel to the Center. I have found this information that works….
    Adobe Premiere Fill Left/Right Effects
    The audio fill effects can be found in the effects window, under Audio Effects > Stereo > Fill Left / Fill Right. To apply either of these effects, select the appropriate clip in the timeline and drag the effect onto the clip (or drag the effect into the Effect Controls window).
    The Fill Left effect takes the audio from the left channel and duplicates it on the right channel, deleting any previous audio which was on the right channel. The Fill Right effect does the reverse, applying the right channel audio to the left channel.
    The most obvious use for these effects is when you only have audio recorded on one channel. For example, if you have an external microphone plugged into the left channel of the camera (and assuming the camera only records it on the left channel), you will probably want to duplicate it on the right channel as well in Premiere.
