Activity Forums Adobe After Effects Question Regarding Particle effect with the use of Images
  • Question Regarding Particle effect with the use of Images
    Posted by Josef Brockdorff on March 14, 2017 at 12:10 pm
    Hi guys,
    hope this finds you well.
    I need your help since i need to replicate this particle effect with the use of images? was this done with a template or preset?
    https://vimeo.com/132082845
    Thanks in advance,
    Josef
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    John Cuevas replied 9 years, 5 months ago 2 Members · 1 Reply
  • John Cuevas
    March 14, 2017 at 1:43 pm
    Looks like Trapcode Form, using images to control the RGB. Check out these tutorials, couple of the ones at the bottom of the page are what you need.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
