Activity › Forums › Adobe After Effects › question regarding intermediate codecs and what matches up with what?
  • question regarding intermediate codecs and what matches up with what?
    Posted by Alexander Gao on January 15, 2006 at 10:30 pm
    I’m doing some cloning work in AE, meaning the same person plays 2 people and are in the same shot. I use some masks and do other things such as curves coorrection and color correction, but other than that there are no graphics or anything. I know that the animation codec is a good one to go from AE to fcp, but this file size is far too large. What other codecs would achieve the same level of quality as the animation codec (because i get a feeling that animation is not needed for such a simple masking and color correction)? (the footage is progressive dv, 16×9)
    Alexander Gao
    “When the revolution happens, I’ll be leading it.”
    Alexander Gao replied 20 years, 8 months ago 2 Members · 3 Replies
  • Joshua Ferg
    January 15, 2006 at 11:31 pm
    Alex,
    I go to FCP regularly and find Photo-JPEG has worked best. Highest settings.
    You should be able to set your FCP settings to read the codec without rendering in the TL.
    Hope this helps.
    Best,
    Josh
  • Alexander Gao
    January 15, 2006 at 11:35 pm
    thanks a lot. any input on what to pick under format options in JPEG for progressive footage?
    Alexander Gao
  • Alexander Gao
    January 15, 2006 at 11:39 pm
    NEVERMIND! I accidentally went to jpeg sequence rather than photo jpeg.
    Alexander Gao
