Activity Forums Adobe Premiere Pro Question regarding encoding
  • Question regarding encoding
    Posted by Ron Weber on April 27, 2005 at 12:27 am
    Okay, I just finished a project in 6.5. I exported it as a movie to Encore 1.0 and had some problems from there. Some of the special FX did not render correctly. So I then used the Adobe Encoder and saved it. Brought it in Encore and made the DVD’s that way.
    I’m done with the project but I wanted get some feed back on this. What do you think happened and is there a better encoding process. The video did not produce the greatest quality. There are some pixelation but I think some of it was the camera not handling the low light.
    I’m going to get a good 3CCD camera next. But, how can I get the best quality from my footage through encoding? What are some of the settings I should be establishing? I know Encore has several ways of setting up but is it better to encode first or let Encore do it?
    I welcome your comments…
    Aanarav Sareen replied 21 years, 4 months ago 2 Members · 1 Reply
  • Aanarav Sareen
    April 27, 2005 at 1:33 am
    You have to give us a little more info.
    Source footage properties?
    Export properties?
