Activity › Forums › Apple Final Cut Pro › Question re 64 vs 32 bit performance with Lion…
  • Question re 64 vs 32 bit performance with Lion…
    Posted by Eli Hollander on July 27, 2011 at 6:28 am
    I am puzzled. My timeline (project) plays more smoothly and with less dropped frames and sync problems when I am in 32 bit rather than 64 bit mode. I am using an iMac i5 with 4GB of memory. Is the about of RAM the problem?
    In theory, the 64 bit should work better, but it doesn’t (I have tried this several times). Has anyone else had that experience?
    Eli
    (P.S. This is a great forum… thanks everyone).
    John Pale replied 15 years, 2 months ago 7 Members · 9 Replies
  • 9 Replies
  • Kevin P mcauliffe
    July 27, 2011 at 1:56 pm
    Hey Eli,
    Looks like we’re in the same boat. I noticed a performance enhancement by switching from SL to Lion, but no 32 vs 64-bit differences. Maybe it’s coming in one of Apple’s upcoming…..”updates”.
    Kevin P McAuliffe
    Creative COW Trainer
    kevinpmcauliffe@gmail.com
    Twitter: @kpmcauliffe
  • Matt Doe
    July 27, 2011 at 3:16 pm
    I believe FCP X runs in 64bit mode even if you are not booted into the true 64bit version of SL
  • John Pale
    July 27, 2011 at 3:54 pm
    64 bit apps require lots more RAM to run effectively. I would at l east double that 4GB to 8.
    that being said, there are no significant performance differences between Snow Leopard and Lion.
    Some older Intel Macs cannot run the 64 bit kernel, but this does not affect their ability to run 64 bit apps or use large amounts of RAM…getting all the benefits of a 64 bit OS. It just means the OS can’t “talk” to hardware using 64 bit instructions.
  • Jason Jenkins
    July 27, 2011 at 4:59 pm
    [John Pale] “there are no significant performance differences between Snow Leopard and Lion”
    Then what is the point of Lion?
    Jason Jenkins
    Flowmotion Media
    Video production… with style!
  • Michael Hancock
    July 27, 2011 at 6:27 pm
    You can make your mouse scroll the opposite way!
    Michael Hancock
    Editor
  • John Pale
    July 27, 2011 at 7:42 pm
    [Jason Jenkins] ” “there are no significant performance differences between Snow Leopard and Lion”
    Look at Apples web pages on Lion. If the new features appeal to you, then go for it. There are lots of them, but they might not be important to anything you do.
    Both Lion and Snow Leopard are 64 bit operating systems. There isn’t a huge difference in performance, though some things might be a bit faster.
  • Steve Connor
    July 27, 2011 at 9:50 pm
    I’m finding stability under Lion to be a problem, more unexplained crashes. When I revert to SL I get far fewer crashes and I’m sure speed is a little better.
    Steve Connor
    Adrenalin Television
    Have you tried “Search Posts”? Enlightenment may be there.
  • Eli Hollander
    July 27, 2011 at 11:03 pm
    Also, the “real” question I had is:
    When I boot into Lion in 32 bit mode (holding the “3” and “2” keys down at startup), I seem to get better performance in Lion than when booting in the default 64 bit mode (you can tell if you are in 32 or 64 bit mode by doing “About This Mac…” in the Apple Menu, then “More Info…” in the window that pops up, then click on “System Report” then select the “Software” tab).
    I am wondering if other people get the same results that I am getting–less stuttering and fewer dropped frames in 32 bit mode than in 64 in Lion?
    Eli
  • John Pale
    July 28, 2011 at 7:57 pm
    I think I answered that. You don’t have enough RAM. 64 bit requires a lot of RAM.
    I’d have a minimum of 8 on that machine
