Activity › Forums › Broadcasting › question on video impedence…
Posted by Alan Teo on July 8, 2005 at 9:11 pmHi… I just started doing multi-cam events coverage recently. I happened to be involved in the equipment set-up during the last show. While connecting the BNC cable to the JVC Video Monitor, I saw there’s a switch which allows me to select between OPEN or 75 OHMS.
What is the switch meant for? and when do I need to put it to OPEN or 75 OHMS???
Mike Cohen replied 21 years, 2 months ago 5 Members · 8 Replies -
Charley King
July 8, 2005 at 9:21 pmThis is for termination. If you don’t terminate the overall video is doubled in amplitude. Yet if you double terminate it is pretty much cut in half. These not necessarily exact measurements but close but I think you can get the point. If you add another monitor into the line such as a daisy chain, you want to leave it open then terminate at the last item in the path.
I hope that makes sense.
Charlie
Alan Teo
July 8, 2005 at 9:24 pmSo in other words, if I don’t terminate at the last item, the video quality will drop???
Charley King
July 8, 2005 at 9:26 pmIf you don’t terminate at the last item. The video will be very bright and clipped.
Charlie
Charley King
July 8, 2005 at 9:30 pmKeep in mind if you should have a terminator in line before the last item you could be double terminated and the video will be dark.
Hope this helps
Charlie
Chuck Reti
July 9, 2005 at 1:29 amIf you have a very long line, unterminated, you may also get reflections (ghosts) back down the line.
Chuck Reti
Video Editor
Detroit MI -
Tony
July 9, 2005 at 3:49 pmAlan,
Think of termination like a facet in which you must either turn on the water to let it flow out (loop to another monitor) or turn off to stop the flow. The last monitor in the loop is the one you must terminate.
Generally it is not advisable to loop more than once because you will start to have video signal roll off issues. I only loop monitors which are being used for content and framing not image quality viewing.
Tony Salgado
Mike Cohen
July 22, 2005 at 7:56 pmA few years ago I walked into a room where some of my videos were being projected. When I got there the clients were flipping out because the video was all washed out. The inept AV tech was fumbling with the projector’s color settings while the videos were playing, much to everyone’s dismay as it obviously wasn’t fixing the problem.
When the tech had his back turned (can’t mess with their setup or make suggestions in this convention center venue) I looked at the setup, moved a terminator from an unused bnc input to the correct one, and problem solved.
Despite fixing the problem, the tech was ripped – he said I wasn’t allowed to touch anything and he could shut the room down yadda yadda yadda. That’s gratitude for ya.Moral of story – termination very important.
Mike
