Activity › Forums › Apple Final Cut Pro › Question on technique for dropping frames / strobe
  • Question on technique for dropping frames / strobe
    Posted by Dean Gatenby on June 26, 2014 at 11:34 am
    Hi this is my first post so if my question sounds stoopid or is in the wrong forum then my bad.
    I have an opening scene i have been planning where there is a body being dragged through a forset and the effect i am going for is quick cuts to black over foorage that seems jerky/fragmented.
    opens with a fade from black to a pan through the forest with birds and all the glory of nature present – then you start to hear the frantic noise of the people dragging the body before a quick cut to a frantic dragging scene for a second (foorgae to appear slightly slower and jerky from dropping frames – cut back to peacefull forest – then cut back to body been dragged again – now we keep cutting from black to footage of the body been dragged with the sound dropping between cuts.
    the best way i can think of to do this is remove frames and maybe use the stobe plugin. i was wondering if anyone has any advice they can lend if they understand the effect i am going for.
    sorry i dont have an example but some of my inspiration i think came from saving private ryan and band of brothers… almost a shell shocked kind of effect.
    any help hughly appreciated
    Thanks in advance
    Dean G
    Dean Gatenby replied 12 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
