Activity Forums Apple Final Cut Pro Legacy Question on PVM-14L5 and 24p
  • Question on PVM-14L5 and 24p
    Posted by Joslyn20 on March 7, 2006 at 1:57 am
    i have a PVM-14L5(not the /1 version). i know the later models of this monitor supported 24 frames per second. i’m wondering how can i tell on my monitor if it supports 24fps? i have my hvx200 connected via component and when i switch modes between 720/60p, 720/30p and 720/24p, the pvm only shows it as 720/60p.
    also, i remember reading a year ago that this monitor supports full rez HD. does this include 1080p? thanks for your help!
    Joslyn20 replied 20 years, 2 months ago 3 Members · 5 Replies
  • Walter Biscardi
    March 7, 2006 at 2:11 am
    [joslyn20] “i’m wondering how can i tell on my monitor if it supports 24fps?”
    if it’s not the /1 version, then it does not natively support progressive scan material.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Tony
    The 14L5/1 is a multiformat monitor and does display 1080 24psf as well as 720/60P.
    The monitors which have a label the multi format label on the front face generally indicate they can do 24P.
    Tony Salgado
  • Joslyn20
    March 7, 2006 at 2:56 am
    walter, tony,
    according to this thread: https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=98&postid=803582
    some of the later model pvm14L5 did support the 24p as long as the serial# started w/ 21 not 20. my serial# starts w/ 21 so i believe based on that thread that my monitor supports the upgraded feature. i’m just trying to figure out now how i can determine that. since you guys have the /1 version, let me know how i can tell on this 24p compatibility. thanks again!
  • Walter Biscardi
    March 7, 2006 at 3:37 am
    It properly switches over to 720p when it receives the signal. It’s a display on the front of the monitor when it gets the signal.
  • Joslyn20
    March 7, 2006 at 3:51 am
    walter, when i toggle through the hvx: 1080i, 720p, 480i, etc…the monitor automatically switches. is this what you’re talking about? also, when in 108024p or 720/24p, mode, i’m wondering if the monitor displays 24p(for example, 720/24p)? thanks again!
